| Hi guys I am trying to trace down a misfire, stuttering issue I have seemed to developed. Here are some of the things I have done so far 1. Ohmd all the injectors 2. Ohmd the coil packs 3. replaced all the coil pack connector plugs 4. Replaced the PTU 5. Check for power on the coil packs 6. Replaced the plugs (using generic cooper plugs ATM) I am thinking I have either a bad ecu or a grounding issue, or something else is going on. Another idea was maybe I have a flakey ECU.. Any feedback would help. Can anyone confirm all the ECU and chassis grounding points?
